Shiv5
Hi guys
ive just removed a ceiling fan and light fitting any I wanted to put back a ceiling rose back on, I can't seem to wire it back correctly. There's 4 wires sticking out (please see pic)
the ceiling rose has the following labels
your help would be very much appreiated
earth
neutral
loop
line
that is a scruffy mess. while you might be capable of doing it, i'd strongly advise getting a local electrician involved, as he/she will make surer it's done safely.
I'll guess the green/yellow is your earth and the blue your neutral. What the black and yellow cables are would be a guess but I assume they are live? And whats hidden under the black insulation tape who knows -- red cables?!?!
Probably best to take the advice given in above posts an get a local electrician to look at it for you .....
Wiring ceiling rose help
DIY Electrical Advice
Shiv5,
Badged01,
