Discuss your preferred method for external sockets in the UK Electrical Forum area at ElectriciansForums.net
O
One_of_them
guys whats your preference when fitting external accessories (sockets particularly)?
do you straight rear entry with cable and cake in silicone to prevent ingress
do you fit the masterseal cable entry grommet
are you a conduit man right through wall and into box
sure there is a couple others
just trying to gauge how others go about it.
bottom entry wherever i can. rear if client wants no cable on show. plenty gunge behind box, though, and a drain hole in the bottom of the patress,
I always use Master seal sockets.
I normally do rear entry (that sounds bad!)
I always drill the small drain hole at the bottom and I always put a nice small tidy bead of clear builders silicone between the back of the socket and wall.
Start by drilling all holes for cable and fixings first (back of the box) and make sure all lines-up and is level. Drill 3mm drainage hole into bottom of IP rated box.
Cable through the wall, builders silicone around it into the hole. Nice ring of silicone around the cable, press IP rated box onto wall and fix with screws.
Tidy silicone up inside box. Connect and fix front.
I also prefer bottom entry, and plenty of gunge in the box till it drains out of the bottom, rear entry is also nice, depends on the customers preference. But back to sockets, i fit them as best i can, depends on where it is to be sited.
Cheers............Howard
Just needed pictures and that would have been a perfect "How To" :D
:thumbsup
Reply to your preferred method for external sockets in the UK Electrical Forum area at ElectriciansForums.net
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
Hi all, Was wondering if you could help please. I'm looking to fit a BG IP66 external socket mainly for occasional jet wash/vacuum usage and...
I've an otherwise small and simple job to do later, out of hours, fit an outdoor IP FSU for a small AC unit fed from an outdoor socket on an RFC...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Looking for some advice; I am intending to mount two led downlights on pillars/brick walls either side of the garage door opening. I will drill...
