uksparks
- Reaction score
- 1,228
Discuss Your thoughts on bonding this gas pipe in the UK Electrical Forum area at ElectriciansForums.net
Just put a clamp on the handle! No need for sandpaper or a blow tourch. No paint on that!.....I'll get ma coat.....
Which will reduce the flow but not the pressure. Nor will it regulate the pressure to keep it constant. That is the job of the governor.
By all means try it and see what happens ...... I'll send flowers to your funeral.
Where's ayjay gone?
It is a new one to me being a Gas Safe Registered fitter !
If there is no meter then the house is not a consumer and the gas pipe belongs to the gas supply company, not the householder so don't bond it.
Nonsense, you obviously don't understand the purpose of bonding.
Bonding is installed to all conductive parts likely to introduce a potential in to an installation with the purpose of maintaining those conductive parts at the potential of the supply earth.
Oh this has been dragged up again I see
Oh this has been dragged up again I see, and yes I bonded it, I drilled a small pilot hole, ring crimp on the end of cable then a self tapper, jobs a good n'
What are you doing here fella you should be giving your lass a rest with the bambino!
Reply to Your thoughts on bonding this gas pipe in the UK Electrical Forum area at ElectriciansForums.net
