The difference being that properly made with a supporting ring under the armour and surrounded in cast resin so no movement is possible it makes a good connection
They are used on high voltage cables with heatshrink they do put a ring under the armourings tho.
Typical bodge !
Electrician : "That is highly dangerous! - That needs to be sorted out ASAP!"
Customer : "But....it works"
I thought they used "constant pressure springs" on moat UG resin joints
They can do I'll dig a picture of a gland using a jubilee clip properly
Not the neatest with the run off bitumen, but you get the idea.
Even better still, who saw the need for the wedge to hold the door open
They probably couldn’t find a fire extinguisher to plonk against it.
This is what really happens when you don’t know your ar$e from your elbow.
Here is a couple from a job I was called to, the rewire had "just been finished by an electrician friend"
I suppose at least one of the "busbar earths" was correctly identified!
Sent from my SM-A300FU using Tapatalk
Reactions: 4 people
Also have this beauty
These were feeding an garage board supplying an electric shower on a 50A MCB.
Also, the water bond was taken from aforementioned garage board!
Conductor size: three sevenths of 16mm!
Reactions: 4 people
that is a deffo bob the builder. even a plumber could do better.
I suppose it's handy if the lights trip while you're having a play with the rubber duck!!!!
Laughed me head off tee hee, don't listen to any Tracey Chapman songs whilst your in there.!
Wet pants strikes again
what, country and western? as in my wife's run off with the dog and the milkman's shagging the cows?
lol nah folk but yeah all that.
hard some c/w songs once. they were on the john denver "learning to fly" album
Nah, she makes very chilled out music no doubt, but she's no Radiohead by any means.
i think her dad is an electrician.
he lives by
Sent from my SM-G900F using Tapatalk
8K
Darkwood,
mainline,
