S
Sussex2016
Hi I am about to begin an apprenticeship with a local company. I need to build up a basic tool collection but will need to start from scratch. ive found one overall CK set and wondered if anyone had any experience or advice on the kit.
many thanks
Junior hacksaw, 7.5m (25') ST tape measure, electricians knife, automatic wire stripper, 210mm (8¼") pocket level, VDE 125-250V AC mains tester, 16oz claw hammer, M3.5 x 6" rethreading tool, Redline VDE 185mm combination pliers, 175mm snipe nose pliers, 160mm combi-cutter, 7 x Dextro VDE screwdrivers (2 x Slotted (2.5 x 75 and 4 x 100mm), 2 x Phillips (#1 x 80 and #2 x 100mm), 2 x Pozi (#1 x 80 and #2 x 100) and 2 x 100mm Modulo) and tool bag.
ae235
Hi and welcome to the forum, I'm sure the lads will be along soon to give some advice and also good luck with your Apprenticeship.
CK kits is generally very good. The kit you show would be a good starting point and then you can add tools as you need them.
Sussex, IMO although those CK tool kits are very nice, I would go for a decent tool tote, there are plenty to look at and build your tool kit up from there.
You need something for quick access and quick recovery.with the CK type you will be forever worrying about, have I put that bit in the right compartment, with a tool tote it's quicker, something I'm sure your employer will be pleased about, plus the CK looks naff, IMO just saying, PS not saying CK stuff is not any good, just don't like those daft zipper bags. Good luck with your Apprenticeship.
With the greatest respect I have to disagree with you on this point. The CK bag has a couple of drop down flaps which means you can locate the tools easily.
It's only my personal opinion, personally I would not use them, with respect of course.
Reactions: 2 people
Worth registering for the trainee section if you haven't already. You'll need to to view the attached thread but hopefully helpful.
For what it's worth I started with one of those C.K. sets four years ago and have replaced most of it with other stuff. Some of it was rubbish and some was good but never suited me.
http://www.electriciansforums.co.uk/showthread.php?t=92466
Sent from my D6503 using Tapatalk
Wiha has an lboxx kit on Amazon for 70 was 60 earlier on in week,think someone bought them up and maybe relisted them. It has pliers long and snips screwdriver set, Allen keys. Add a hacksaw,hammer tape measure and pad saw, you should be set. Buy quality tools and covet them their are some tea leafs out there. Some big names such as knipex wera Bahco are good but I've managed with lower quality until finances allow. I personally don't like that ck kit. To expensive for the quality.
As a side note don't buy a veto till you have the tools to fill it. 160 pound hand bag to carry 40 pounds worth of tools. Spend your penny's wisely.
The tools you'll need will depend on the type of work you're going to be doing - as a general standard you'll need a medium flat and pozi screwdrivers, something for cutting and stripping cable; I use cable shears like these:
https://www.tlc-direct.co.uk/Products/BHJ1307.html
and I find a stanley knife is useful in most situations.
Most things can be fixed with a hammer, pliers are handy for terminating T&E, a pair of sidecutters for cutting what you don't want to blunt your cable shears on, a small and large adjustable spanner, a padsaw and maybe a set of short rods if you're going to be doing anything with plasterboard, and some good grips such as Knipex alligators for holding things.
If you're going to be doing a lot of domestic work you'll probably need a bolster chisel, boat level, a 'bashing chisel' for chopping out bits of wood, plaster, celotex etc. If you're cutting in a lot of boxes a box stencil can save time, and a rethreading tool if you're going to be going around after the plasterers.
For commercial work you'll probably need a hacksaw, file, maybe a bush spanner.
If you're going to be moving around a lot it's best to keep everything in a bag which is easy to carry, if you're going to be working in the same room all day a sturdy box can be used to sit on, stand on, or saw things on, but either way you'll need something with a storage space flexible enough to adjust your selection of tools to suit what you're doing.
As you can see there's a lot to consider; instead of going out and buying a load of tools you might never use it might be best to wait and see what you're going to need and build up your collection as you go. Nobody will be expecting you to start with everything - we haven't even touched on power tools, or even a voltage indicator which is essential for safe working.
Reactions: 3 people
that CK kit is a good starter kit.i have to disagree with pete. the beauty of kits like this are that youhave a place for every tool and know thatyougot them allback in.
Reactions: 5 people
As above, that kit is well overpriced for what it is.
If you are after a good solid box, the Stanley waterproof structural foam ones are top notch, and are at silly money at the big orange shed right now Stanley Toolbox (W)305mm (D)267mm | Departments | DIY at B&Q
Fill that with a half decent plier set, a half decent driver set, all the other bits that make up the CK set and I reckon you'll be at half the price that CK are asking.
I have used that toolbox for about 7 years and only just lately demoted it to tester carrying duties. It got so full of tools that every tool retrieval became a rummage. It should be more than fine for an apprentice with a small tool set though.
Apart from grips, cable cutters, and at some point in the future a voltage indicator, cheap and cheerful is fine. I'm still using the same VDE pliers and sidecutters I've been using for the last 10 years, got my insulated screwdrivers from Aldi and most of the rest of my tools from B&Q or the local clearance shop. Because I've built up my tool collection from scratch and bought what I need, I know exactly what I've got and have a good idea of what tool to use in any situation.
My tools might not be much to look at - they're not all the same colour or brand, but they look a lot better next to me in my bag than they would if some toe-rag pinched them.
many thanks
ae235
http://www.electriciansforums.co.uk/electrical-tools-products/109212-apprentice-tools.html
post 8&9 on the above link.
listen to this nugget of advice, the veto will break you back if you overload it as well.
a set of screwdrivers
hacksaw
setsquare
file
side cutters
pliers
long nose pliers
tape measure
tote bag
insulated crimpers (red,blue,yellow crimps)
water pump pliers x2
allen keys
hammer
(im sure im missed essential tools off this list)
cable shears are nice to have but not essential, concentrate on getting the other tools first, i was much like yourself
and had a better toolkit than a lot of electrcians when i was on my apprentaship
dont buy too much now depending on the kit you use you will need different tools, for example i carry torx drivers,security bits, square drives etc and loads of other bits.
had an electrician that has been in the game 10 years ask me what some of the tools in my bag are i used them daily for a couple years and he had never seen them before
Sent from my SM-G900F using Tapatalk
A lot of electricians make do with the minimum, these are usually the ones that are the first to take the mick on how much you spend on tools, and the first to ask to borrow them. Invest in them and don't lend out I've lost count on the amount of shifters I've had returned yet I haven't seen them again.
Reactions: 2 people
Give pete a break...he comes from an era,where whipping a tool out from a zipped enclosure,was nothing to do with work...:yesnod:
Reactions: 3 people
Thanks for that PEG took me a while, but got there in the end, nice one.
One thing in defence of the zip type bags is that you can see at a glance if your gear has been returned, leaving an expensive piece of kit for some lucky bug*** to find is heart breaking.
I have a similar CK kit illustrated, I bought it from a chap on here a few years ago, at a very good price.
I must admit I would not of paid the retail price for it , but with the exception of the hacksaw I an generally pleased with it.
The auto 'missing' alarm is the best feature of this type of bag.
Don't think they'd invented zips then. Most likely buttons only. :wheelchair: :smile5:
I agree that the CK bag is good to work out of. I have my regularly used tools in one and it's easy to find a specific tool and better than a toolbox for spotting whether tools are missing when packing up.
Listen up you bunch of Divs I'll have you know, nah I aint going to stoop so low lol
Reactions: 3 people
An electrician should have the tools he needs, but for an apprentice starting out, 'the minimum' is fine. I started out with 'the minimum' and went out and bought a tool every time I had to borrow one. That way you get a feel for what are the essential tools, and what amount to gimmicky ballast in your tool bag.
Conduit cutters, SWA bladerunners, full sized rods, socket and spanner sets, MCB screwdrivers and such like may be useful if you're doing a lot of work which uses them, but you can live without them.
Two quality pair (minimum)of 'Vice' grips are a God send. Long nose and standard.
Maybe not at apprentice stage , but you will never regret buying them.
When I said minimum I was referring to shankys post on how, sparks of ten years service not knowing of some of the tools he was using . I wasn't suggesting an apprentice should have a full tool kit, straight off the bat. Does the jib handbook have a tool list in it?.The sjib handbook did, giving an idea of what apprentices should have at the end of each year. Tool kit will take a while to build up on apprentice wages.
nun is right, im sure most here will agree there tool kit would cost way over a grand to replace, way to much for an apprentice to buy.
Yes , a lot more than an Iphone and all the other electronic gadgets that are a must these days.
IMO, all you need starting out is good quality hand tools, in a tool bag/box of your choice. I was a great believer in a nice canvas tool bag, several which I still have to this day. ( new ones) lol
Starting out tools list
Electrical Tools and Products
Sussex2016,
7029 dave,
