- Reaction score
- 10,616
I expect the later easier if your in a wheelchair or elderly & infirmed.Isn't a switch inside a low cupboard at 450mm high easier to reach than an isolator above the work top? With its 600mm depth to reach over?
Discuss Can Plug Sockets for Dishwasher and Washing Machine be Placed in Under-sink Cupboard? in the Electrical Appliances Forum area at ElectriciansForums.net
Ok then; I expect the later easier if yourIf the kitchen is specifically for disabled access there are detailed guidelines on access and positioning.
Scottish Regs stipulate isolation switch above counter top for under counter appaliances. I always put Socket outlets behind the appliance fixed to the structure of the building. Regs are to be followed whether a new build or old.In a new build or major refurbishment, perhaps yes to comply with Part M Building Regs 'to assist people who have reduce reach'. But it only specifies min & max height of switches etc. Designers of new builds often use the central set of DP switches. What do the Building regs in Scotland state?
As regards socket outlets in cupboards, how else do you supply an appliances?
Yes that makes sense. If the elderly or infirm need to pull the appliance out to do a quick repair its easier if the socket is counter top. Can't imagine they'd get somebody able to do that for them.Ok then; I expect the later easier if yourin a wheelchair orelderly & infirmed
Should an appliance burst into flames having the isolator above and behind it isn't really much help.
I also agree there is little point in sockets behind appliances.
Only in Scotland does this 'reg' appear to apply.Scottish Regs stipulate isolation switch above counter top for under counter appaliances. I always put Socket outlets behind the appliance fixed to the structure of the building. Regs are to be followed whether a new build or old.
Reply to Can Plug Sockets for Dishwasher and Washing Machine be Placed in Under-sink Cupboard? in the Electrical Appliances Forum area at ElectriciansForums.net
