Currently reading:
Pete's Videos Quite a competent Sparky I think
Discuss Quite a competent Sparky I think in the UK Electrical Forum area at ElectriciansForums.net
Strangely we were also correcting a no earth fault on a lighting circuit in some offices today, we did carry out earth continuity at every point in the circuit, live to earth insulation resistance efli etc. and completed a minor works certificate. Also changed any green earth sleeving to green/yellow and fitted coloured sleeving where needed.
im really interested on why the previous sparks just didn't bother connecting the earths. I mean, isn't that the very basics of working with electrical systems.....
makes me think there was a bigger picture involved. Maybe the sparks found there was no earth to the property and just thought "you know what, there's no point in connecting the earths anyway".
or, maybe he was just a DIY'er
Pretty simple explanation, either he was a butcher or he'd tried to find a fault on his wiring & couldn't so left earths disconnected to stop RCD tripping. (Oops sorry that would also make him a butcher).
Sadly he wouldn't be the first or last to do that.
What is this lads missus playing at? Letting him go out in the morning with no cooked breakfast inside him, and having to go to McDonald's for a plastic one. Mind you, I only saw him pick up two tools all day, one of them a dodgy looking socket tester. Spent most of the day supping coffee and yapping, obviously not self employed.
I'm not convinced that he actually has a missus. But I'm pretty certain he's handled more than a few tools in his time. ;)
Welcome back :)
Ta. I had an extra self-enforced few weeks off but couldn't resist a return. I am going to be on my best behaviour now, however I will still be monitoring the grammar, I have seen some shocking examples already, and I see George is no better.
Don't forget the spelling as well Mate, some of it is atrocious
Deleted
Would there ever be a time where not terminating the earth is acceptable? I have worked with a NICEIC registered spark and when it came to extractor fans or plastic one gang switches where there wasn't a terminal he'd say just cover the whole earth conductor in sheathing. If it was a 2/3 gang switch or any switch with more than one cable we'd use connector blocks but I would of thought that you would still do that instead of just leaving it disconnected???
Where would you connect them if there no terminal?
I feel for him. He's clearly proud of his work to show it to the YouTubes.
Unfortunatley my first thought with the D.B. was "Where's the 'Safety Electrical Connection - Do Not Remove' label on the externally mounted M.E.T.?"
Then I realised I should probably be doing better things with my spare time and assess my life choices right now.
Reply to Quite a competent Sparky I think in the UK Electrical Forum area at ElectriciansForums.net
