You never know if things you are buying are genuine or not unfortunately even reputable dealers have been found to have been supplied with counterfeit stuff.
Reactions: freddo and ruston
Tricky one , substandard batteries have been built in to Phones /Tablets,
and caused issues -- (No ohh its counterfeit get out clause there) I'm 50/50 with this ...
Reactions: ruston and freddo
Agree , you can't trust the backside you sit on these days.
Hey rus, even youngsters can get the runs after a night out on the tiles, you know. ;)
Reactions: ruston
Trap in those "toxins" With immodium instants..
(then gas your workmates)
--One on my Nans said "All pills" had hidden consequences !--
and you want a EICR on this??????? After I've ripped it all out and fitted a much bigger DB and some trunking. then I may do it.
They want a second opinion maybe?
I only installed it last week, whats the problem??
shame really. shop has 2 merlin 3p boards, all neat and proper colours (red/yellow/blue/black. all tests fine, then some cretin has added that abortion.
that would be the builder who put up the partition walls and false ceiling expect.
best part is. 1 MCB feeds the tills. shop trades 7 am to 10pm. no chance of doing anything with it unless..
1. they shut shop for a day..... no chance.
2. they pay me £50/hour for night shift. .... negotiating.
I have a 1Kw silent suitcase type genny that I use in that sort of circumstance.
tills on extension lead, start at 9am home for tea time.
everyone's a winner
Start at 6am then.
Reactions: static zap
Start at 6am then.
Love it, start at 6.
from 6.15 onwards, every 10 minutes you will have someone reminding you of the time left before the tills MUST BE BACK ON.
sometimes pressure accelerates work speed.
sometimes not!!
Reactions: Jim_e_Jib
Once its off its off. Do loads of retail tests and one till circuit is no hardship. Probably two circuits including the submain.
And one more maybe for the router.
No CPC to metallic fluorescent light tube fitting. There was an attempt to bond it to some pipe work but a plumber appears to have updated the pipe work.
Reasons not to put a water heater on a 13A plug #1324
Should have used a bakelite plug top like in John Ward's recent video.
MK Safety Plugs are super plugs for high current appliances. I have several here, I quite like the charcoal ones. Have a few not so common versions like the one pictured too.
This is still one of my favourites from a while back......and still can't fathom out how he managed to screw the rose cover on.....but it was
Reactions: 123 and freddo
Nice way to wire a switch fuse
Just a thought you think it would be useful to post a contrastin thread where you have seen admirable work done?
I am sure everyone has come across work you have thought now this person knew what they were doing, perhaps should shocase that?
There is one somewhere :)
I think Westward started it and there are some good examples of how things should be done in there. :)
I started this a while ago but has died off a bit.
Reactions: Markyd and JLeague
Reactions: westward10
There is one somewhere.....not as much fun as this one though.....:tearsofjoy:
Reactions: DPG and static zap
Coming to conclusion we prefer something to moan about / feel fortunate its not us !
Reactions: DPG and Jim_e_Jib
Coming to conclusion we prefer something to bitch about rubbish work than praise good work....and bitch about the guy having too much time on his hands
Fixed that for you 5 words
Reactions: Barry123
Fixed that for you..
Mustn't forget envy for guy doing well .
(It doesn't always last )
..estrogen in my water supply must be kickin in...
Message deleted wrong forum location
Temp builders supply whilst extension is being built. At first the mess of sockets were in a wheelie bin and the CU was covered over with a bit of tarp! If you looked up you could see the sky clearly above your head! This is a commercial premises and that board is a sub board fed from an MCB on another dual RCD board, so when it tripped it took half the building out...
what's the IP rating of a wheelie bin?
They were all in the yellow bin at the top of the first photo. It had tripped at least three times, either due to condensation or the good inch worth of moist dust at the bottom of the CU. What is silly about it all is that it took a mere 30 mins to strip out the redundant sockets. Bearing in mind this is a dentist's and every time it tripped they lost one chair and the compressor went off too. That's probably a fair bit of lost revenue for a profession that pays well.
It's still not ideal by a long stretch but the roof is going up this week at least. I told them it should not be energised as is and left it up to them. At least the RCDs work ok though !
A stupid attempt at installing an inline fan.
Powerline adaptors, the left one is connected to a broadband router just out of shot, the right one is connected to a card reader sat next to the router, the only internet connected equipment at the premises...
One of several sockets wired in twin red 1.5mm cable, all had reverse polarity.
:neutral:
Oh my god, they couldn’t even get it straight an level
My 6 year old apprentice could do a better job.
P.s. keep it quiet, he is not on the books and I don’t pay him minimum wage.
:D:D:D(Grandson):D:D:D
Reactions: JOURNEYMAN
8K
Darkwood,
mainline,
