Darkwood
Also noted while I was there that the extract fan has no ducting to the exterior at all and instead vents through a 4 inch wall straight into the staff kitchenette via a shutter! There's a list of other electrical and building work horrors that the builder has done on behalf of the new tenants. It beggars belief what some people will accept and pay for.
Don't know what's worse, the missing cover on the esco, the link between neutral and earth after the meter or the fact that someone has managed to install a new board whilst this still exists and didn't even bother with a glam for the tails.
In a HMO somebody has been very creative with bypassing the meter, so they unscrewed the neutral in the incomer covered it in tape then shoved it back in, used the earth as the neutral as its a pme system, completely butchering the cu in the process.
Picture number 6 is after I changed it back, its hard to explain but they removed the neutral from the meter by taping the end up and putting back in the main fuse earth/neutral block and used to earth from where the pme neutral/earth block is to bring a neutral into the fuseboard, only reason i can think of somebody doing this is to jump the meter ?
Someone put a lot of thought into this but obviously not into the safety aspects of it!
This will raise some eyebrows! Found at a village hall that had been recently inspected by a 3rd party. I was there to replace some lights and circuit protection. Nearly fell off me steps when I took the lid off this!!:eek:
And no it wasn't me who blew the fronds off, it was the previous spark who didn't need the power off to swap out some mcbs! Oops
Yeah they are thin the forks! But it is wylex!!
Ahh my trusty old non bs131 steps have rubber feet and I had switched it off prior to removing the cover, and yes there is no need on this earth to have a db that messy!! I couldn't leave anything looking like that! I did offer to rip it out and do it properly but they haven't got the funding to do it unfortunately:(
8K
Darkwood,
mainline,
