Darkwood
i have 3 of them in my toolbag. 1 is slightly different.it has a forked business end, so in a bunch of conductors, as you sometimes get in multiple switches. it don't pickupfrom adjacent cables. you just put the forked bit over the suspect conductor.
I keep 2 and usually prove them on the supply so to speak before use
I'll be getting this single point contact tester that's available asap, it will be invaluable
easywy. switch off what you think is the OCPD. plug in kettle. if you ain't got tea within 5 minutes, it' proven dead. 9unless , of course, the kettle is FUBAR, then it's guess again.
I got caught out by something along those lines many years ago. Amongst other things, I managed the phones at my then employer - and on this occasion I didn't have my butt set* to hand (I think I'd either been using it at home, or lent it to someone), so I had to use an ordinary phone to test a line we were having problems with. Unfortunately, the phone I picked up was faulty, so I incorrectly diagnosed the line as faulty ?
* Butt set is a term used for an engineer's (or linesman's) phone which is designed for testing lines rather than for conversations, so has some different/extra functions and a form factor more useful to the task than a typical phone.
Cables live even with iso off.
Going to dodgy old style three phase plug.
Then out into SY cable.
All about to be removed and aux out going to the virtually empty DB above
Not even tried to put the live singles into the tray work
True but if one trips and DIY Dave starts to play around thinking everything is off then you could get a nice zap
I'd say that's Dave's fault. He shouldn't be playing about with it anyway, especially 400v 3 phase.
Loads of them in domestic, we know. There's more and more getting involved with commercial and industrial.... scary stuff.
I always use TP breakers but there's nothing wrong with 3 cartridge fuses. Millions of those perfectly decent circuits in operation.
I don't think those boxes have a terminal to connect a cpc to. They are pre cpc metal back boxes, with insulated threaded blocks for the switch fixing screws.
I had a box of 100 Crabtree brass earthing terminals that I used to update the likes of these.
Well spotted, but why not use a connector or something. The main problem came with breaking the cpc. Half the circuit wasn't earthed (incl fluorescents)...linked the 2 earths and it was, so cutting 'em back broke the line.
Sod of a job.
Its arrived and have to say I am quite impressed, with the removable prong bridge it act just like any other Volt Stick, but with the bridge removed it is much more selective.
I have obviously missed something in this thread, what is a single point contact tester if not a volt stick?
Voltsticks are generally non contact. They work over a small gap. No electrical contact.
I thought a volt stick was a non-contact tester? Where’s this single point doo dah coming from?
I must admit I use a non contact tester myself tracing switch wires in multi gang switches, but would never trust it to prove dead.
my two prong tester does ac/dc and has lights for approximate ranges ie 3,6,12,50 110, 230 and 400v
Can also be used as a low power continuity tester for fuses etc
It's like a phase tester but insulated
Works on capacitive coupling I think , can't find the link atm
In the car park of the local Screwfix, but predates their occupation of the site.Some disused 12V chargers (box has a transformer and PCB in it), but look at the quality of the SY cable installation! Now it is opaque and split due to UV. There must have been around a dozen of them in total.View attachment 87907
Wouldn't surprise me if some prize pi$$ocks think they're for recharging their car batteries.....maybe even Screwfix customers. ?
Been helping a friend out who has just moved into a 1970's built and bodged ever since house. Lovely consumer unit, sockets in the bedroom not working, (lost neutral) on closer inspection as the cable was only about 2foot long, this was the cause hidden away in all the gash wires looks like it was snipped off for God knows what reason when the con unit was upgraded, no faults found on the cable! Final one was ripping out the kitchen bodgery a rake of spurs off spurs and a cooker hood that went dead with the cooker, removing the isolator face and outlet plate gave no answers so out came the chisel and hello what have we here then!
8K
Darkwood,
mainline,
