Darkwood
Fire alarm system, thank goodness I didn't have to work on it. only one conduit is bushed into the control panel, 3 have female adaptors but no bush, one is just poked in and has a cable tie around it. The less said about the dangling pcbs the better.
The conduit to the call point has no fixings other than the female adaptor in the top of the box.
Fire alarm system, thank goodness I didn't have to work on it. only one conduit is bused into the control panel, 3 have female adaptors but no bush, one is just poked in and has a cable tie around it. The less said about the dangling pcbs the better. View attachment 110786
The less said about fire alarm installers, the better.
Shortest route from A to B. Swing out under trunking lid. Notch conduit boxes. Just whatever gets the job done, tools packed up and on the road home at the earliest possible time.
Don't get me wrong; there are some good guys out there, but the good guys are few and far between. Most turn up on site swaggering like the fourth emergency service, suck air through their teeth and then turn out rougher work than most people would think possible.
You forgot, hand on chin and slow head shake from side to side, tends to happen with all trades though.
I used to be work in this area and I agree! Though I did more fault finding and rectification than installing.
Several large firms used to sub out installations and getting a good job entirely depended on whether the subbies had high personal standards and were willing to go the extra mile while getting paid a sub-optimal rate for it. A rare few did this regardless, but needless to say this was the exception not the rule. The install usually stayed appalling for the first year until the service team went out for first annual inspection and testing, had a hissy fit, and then one of us would get the call to go and "tidy it up a bit" which often meant doing most of it again much to the irritation of the boss of the service side.
My suggestions that it would be better to keep an eye on the original install fell of deaf ears, and I eventually moved to a much smaller firm, a period I look back on with fondness as the guys were brilliant, teamwork at its best, and high standards.
I just had experience of this yesterday.
Was on my ongoing job at a funeral directors where they’ve built a second mortuary inside the garbage they keep the cars in.
There was a smaller room there before, used for coffin storage, and had a smoke detector in it.
Alarm engineer came, disconnected the detector base, pulled out the cable back to the call point and put the EOL in the call point.
Now the new room has been built, although a little bigger floor area and height, the same engineer turns up to “put the detector back on”
He spent over an hour on the phone to his boss asking if this room actually needed a detector or not…. admitted to me that he didn’t really know the regulations…. And seemed to me like he was swerving the job.
10 to 12m of FP200, a handful of P clips and the old base and detector…
To my mind it’s just as much risk as a storage room. More electrical devices, chemicals… staff will be working in there for some time, not just in and out.
“Oh, it’s an install job now.” teeth sucking noises
You could have had it done the time you’ve been on that bloody phone.
But i was assuming the box was attached to the cpc.
do you think there is a need to bond the pipe, assuming the cable comes into the box double insulated?
Personally i was thinking if the flex was secured inside the back box with a cable clamp then the tube need not be bonded, if it is free to move then i think the tube should be bonded.
but I am open to peoples suggestions.
On a related theme, my mate just died who invented the throat lozenge. There was no coffin at his funeral.
I see them walk in to newly competed buildings, with almost everything done for them, and still leave the place in a mess. To be fair, fire alarm installers are still a few steps above the guys who do intruder alarms. They walk into the same new installation and start work on a spiders web.
And that sheathed cable is connected to a metal clad FCU which is connected to the copper pipe so makes it an accessory point. 411.3.1.1 states this very clearly
If the copper pipe isn't connected to the fcu and isn't an extraneous conductive part and the cable is double insulated, then the pipe isn't an exposed conductive part and wouldn't require bonding.
The few I have seen didn’t have any teeth
Looks fine to me.!!!! But REALLY don’t like the Brown/Cream coloured role of Lino, to the left of photo.!
Newly added data points.
I've seen worse, much much worse !
Went to test the cabling left behind by one tenant when they vacated an office, only found 2 pairs connected but on some it was 12&45, others it was 36&78 (or something like that), but also with pairs swapped so 36&78 might appear on 12&45 on the other end. Plus a few where there was nothing connected according to the tester.
Story was that the previous tenant (also a client of ours) had several offices, when they left, they had their electrician separate the networks so each was separate. No offence intended, but like previous criticism of plumbers and alarm installers, "a few" electricians really shouldn't be let loose with network cabling - especially if they aren't prepared to invest in at least the most basic of test equipment.
So, anyone like to guess what was wrong ?
One worked to the A standard and the other the B standard.
More fun than that - mixing A and B would swap pairs butvstill leave 4 pairs connected. In this case, only 2 pairs were connected between any patch panel socket and wall socket.
Thise who've worked with network cabling for a while will know that the panels have different terminal layouts. This may or may not work ...
Some have the terminals like this :
45 12 36 78
Bl Or Gr Br
01
02
Bl Or Gr Br
45 12 36 78
i.e. all the terminals for port 1 are in a line on the top, with those for port 2 in a line at the bottom.
Some have tbe terminals like :
45 12 45 12
Bl Or Bl Or
1 2
Gr Br Gr Br
36 78 36 78
Needless to say, the clueless idiot didn't bother looking at the markings and used the wrong layout. So socket 1 had 2 pairs from port 1 and 2 pairs from port 2. Then socket 2 had the other 2 pairs from ports 1&2 ! And so it went, with the added bonus that none of the cables were numbered and he'd mixed a few of those up as well.
Basically had to pull all the cables off the panel, work out which was which (give the tone set an outing), and reterminate them.
On another occasion, the tenant took their cabinet and were supposed to leave the cabling. Something got lost in translation, as their lecky just chopped the bundle of cables - fortunately, leaving just enough length to re-use them (again, tone set job to work out which was which).
American and British, it doesn't stand for those specifically but it's a good rule of thumb. Everyone use B for British across the board.
I'll remember that - didn't realise it was that simple.
Bought my first RJ45 crimper back in the summer to make up half a dozen cables. All worked first time, except one 40m cable, so I invested in a cheap cable tester recommended in a thread on here. Soon found the problem using that. Master was sequencing 1,2,3...8, while the slave was sequencing 8,7,6...1 - I'd crimped one of the plugs on upside down. Could make out which is was through the translucent plastic of the plug, so five minutes later and one scrap plug, all was good.
I find this to be a decent tester for the price.
Also using through hole wiring plugs makes life easier
... I'd crimped one of the plugs on upside down. Could make out which is was through the translucent plastic of the plug, so five minutes later and one scrap plug, all was good.
You've reminded me of an "incident" from a good few years ago. My employer at the time managed a campus WAN for a science park - each office/unit was pre-wired with a couple of network points, and one was cabled back to a switch port. We could remotely provision internet access just by configuring the port and allocating them an IP address or range.
Unfortunately, wherever you put these sockets, it's going to be in the wrong place for someone - and sure enough, a business moved in but needed the internet connection to their server room the other side of the unit. So one 40m cable and a few lifted floor tiles later, internet provided where it was needed. Only it "didn't work".
We ended up on a 4 way call - me, the people who at the time managed the network for us, the customer's IT guy, and their external IT support. It turned out, the guy "knew" he needed a crossover cable so cut the plug off and fitted a new one wired as a crossover. - neither our switch, nor his firewall had auto MDI (most devices will automatically switch modes as needed these days so crossover cables are rarely needed, this was some time ago).
The customer's IT guy talked him through finding another crossover cable and an inline coupler. The customer said he'd found one and "it's yellow, is that OK ?" His IT guy responded as I'd have loved to ... "I don't f***in care what colour it is as long as it's crossover".
Needless to say, with the extra crossover in line, our "it's not working" service sprang into life. I managed to refrain from "I told you so" (or something to that effect).
8K
Darkwood,
mainline,
