Darkwood
Just for fun...my very first attempt at using LEDs...I took an old iMac. stripped the innards out of it, put the driver inside the body, led the mains out through an existing aperture with a grommet in it, added a double pole inline switch, stuck the LED tape on the bezel, having routed it through the base...and hey presto! A swivelling, titlting, make -up mirror...mirror courtesy of Ikea for £1.50...
OK, it's not perfect, but a fun project that took just over 2 hours to make. Shoot me down if you like! It was fun to make, and the next one will be much better!
I think new cabinets might be a good idea, the site owner probably doesn't realise that they are their responsibility.
Good point, but how does one go about changing a cabinet that the DNO's cutout & meter is in?
I guess it might be possible to cut away the old box and fit a new one "around" the kit with a gaping hole in the bottom to clear stuff, but the only proper solution is going to involve the DNO replacing the cutout, and the meter supplier re-doing their bit, etc. An no power during the operation of course, which becomes an issue of they both of them can't complete both jobs on the same day.
I've changed a meter box with a cut-out in: the DNO turned up, disconnected the supply cable (taped a boot over the end and left if flapping about), then sat and watched while I changed the box, then reconnected the cable in the new box. They waited till I arrived to start disconnecting. I did feel a bit self-conscious being watched, but I think they (2 guys, in separate vans) were not in any hurry!
Adding a socket in my Daughters bedroom, had no end to end continuity on the line conductors.
After some fault finding, I found the cause. Just butted up together and taped!
I joined the line conductor with a Wago and also put a grommet in the back box.
I prefer to use the wago 2773 push fit in that scenario as there is no chance of the levers being pushed up when the socket is fitted.
I suspect that at some point the insulation had been damaged where the break is and the exposed copper shorted to a sharp edge on the back box or an earth strap on the back of the socket, blowing a sizeable chunk of the copper away. This had been taped up as a repair to the insulation, but the weakened wire has subsequently broken inside the tape.
First day back to work in 2024 and it's started already. Thank goodness this is all being demolished.
Junction box as found, lid missing, metal box not earthed, neutrals from multiple lighting circuits mixed up, wiring extended via front of box. flexible conduit poked into female adaptors.
This total mess was behind the plasterboard. Someone actually installed this. Very little in the zones, singles unprotected all over the place. The whole building is wired like this in flexible conduit buried wherever.
A closer look.
I didn't photograph all the live cables with taped up ends, or any of the twist and tape cable joints.
A closer look.
There was probably a time when someone thought it was a job well done and beyond the minimum requirements.
They use a lot of cable in smooth flexi conduit all over Europe… and the white stuff there is possibly the closest thing we have that is similar.
Therefore, I deduce Doctor Watson, that this installation was put in by none other than…… (dramatic pause) …. A foreigner!
Ok.. that’s not fair, there’s plenty of non Uk sparks that are good and do have an understanding of our bs7671…. This one apparently doesn’t.
What’s that old song? “Rip it up and start again….”
Dramatic difference between the black conduit you can buy in TLC (20mm Flexible Conduit Pack c/w 10 Glands - Black | Flexicon (FPP-CP20B) - https://www.tlc-direct.co.uk/Products/AF20BSB.html) you get glands, but in Europe you get a draw wire already installed, but no glands, back box's are unsuitable. (https://www.leroymerlin.fr/produits...a/gaine-icta-diam-20-mm-l-100-m-62900572.html)
That sort of flexible conduit is one step up from being of no use whatsoever. Awful stuff, although I invariably install quite a bit of it in stud walls to provide a route from A to B - generally short runs to an exit blade or for the likes of low voltage door controls.
Ok for wiring and keeping cables together under worktops/benches in rooms like kitchens or workrooms, where access is awkward. Or saddled inside cupboards, even.
^^^^^ so not only has a neat installation Benn made rough, but was that RCD needed for fault protection? Looks like a TT system to me!
Sy
Oops just looked again and PME I take it from the second Henley/ service blocks.
8K
Darkwood,
mainline,
