Edgers
Essex
Hi - installing this on the outside wall of my house. Cable is usually 3 core but socket has 2 earth terminals. Do I junction the earth cable into two and attach? What do I do?
Either one is OK,if you look you should see a metal bar linking the 2 cpc / earth terminals
Thanks so much for replying and yep, I can see the bar now. One other question, which is probably really stupid, but for now can I wire this like an extension lead - plug in to another socket - or must it be hard wired to the circuit? It's only to run some outdoor lights and a hot tub pump. These were running from an extension reel before
Thanks in advance for any suggestions
Edgers
Essex
Wiring for outside socket
DIY Electrical Advice
Tags Tags
wiring
Edgers,
Edgers,
