Only do this if the plug is a normal household plug like the one on your hairdryer or iron
Cheers..........Howard
Hahah, class. You know MC, just like the type that's on your washing machine and the hoover. Hopefully there isn't one on your cooker though, but possibly on the microwave !!!
Just think/treat the downlighters as you would a normal pendant. The only difference is that you take the switch wire and a neutral to the 230V side of the transformer (instead of the pendant) then cable the 12volt side to the downlighter.
thanks widdler, i meant to have posted that last comment on the comment above yours, not to you mate
before starting with the downlights, cut the holes first. then insert several rats ( with a length of fishing line attached to each ).. to eat the insulation that is packed in stopping you feeding your cables above the ceiling. when a rat exits through another hole, use the fishing line to pull in your cables. when you've completed this task, you will probably be hungry, so cook and eat the rats. then you are ready to second fix.
Is it true that women have smaller feet so that they can stand nearer the sink?:biggrin5:
:oops:thread going off track
coz it's a woman thing. and i can honestly say that i have never used straighteners ( straitjacket, maybe ) or a hair dryer in my life ( and no, i'm not bald )
So MC, amongst all the drivel and handbag swinging, did you understand anything that some of the lads have suggested?
:D
how do i get these little buggers in then?
Talk Electrician Forum
Marie-Claire,
twotankards,
