C
crabapple
when wiring lighting for suspended ceiling, is i ok to just chuck the cable over the top or does some other measure have to be taken(i mean i could use baskets, but on slim budget)
You say 'should be' but provide no ref' regulation to confirm this, as far as reg's goes they are not to be run across grid ceilings, the method you choose to achieve this is at your own discretion, will agree you method you suggest adds that pro' finish but when money is on a shoe-string their is nothing wrong with just running the cables around in a 'all round band' loop system.should really be in conduit then onto short run basket, or if mcurdy boxes should be conduit to mcurdy then the flex to the back of the fitting...
What about in domestic, on a normal plasterboard ceiling? It's common to find cables laying on top of the ceiling, and also junction boxes.
I like them, hadn't seen them before; looks very easy to use, I must have misunderstood!To keep cable off the grid, you could use these types of clips.
There was recently an inquest into the tragic death of two fire fighters in Shirley Towers Southampton. One of the contributing factors was cables hanging down from a suspended ceiling after it collapsed. There were calls for the cables to be secured in flame proof trunking but lord knows when or if this would filter through to the Regs. There was a photo of the cables and the blackened shell of the flats ( but can't find it) and it wasn't difficult to see that this would be a problem in all that smoke and heat. At least if they are secured with something flame proof they would at least stay up and out of the way.
Philpot
