Can anyone assist with identifying what this transformer is?
The customer has a 3 phase supply cable run up their drive, but apparently the conductors have bee paired up and is now only single phase supply - they think the transformer was swapped a few years ago after a major fault, and that things changed then.
They thought the transformer was single phase as well, as it only has the 2 HV cables coming in to it, however it has 3 x LV connections coming out of the transformer on the back, which is making me think it could well be a split phase supply from the transformer, with 2 phase plus neutral on the LV side, and the neutral on HV side being sent back via the L1 / L2 conductors as in delta formation 3 phase, or similar. I suppose they could be live, neutral and earth on single phase, but I'd have thought they'd have paired up neutral and earth before the transformer, and usually they'd have spiked the earth connection at the pole IME, and no sign of that.
Obviously I'll be checking with the DNO, but just wanted a quick sanity check on this as it make a lot of difference as to what pv capacity is likely to be feasible
ps the transformer is supplying 2 farms on either side of the road, so I'm thinking they might have just split it to one phase per farm when the transformer was renewed.
answers on a postcard to the usual address please..... ta
