LukeD
Supporter
Anyone only ever use 1mm T&E for domestic lighting (Average 3 bed etc) Or are you using 1 mm &1.4mm for drops and runs etc ? Now that 90% of stuff is LED bulbs etc . Not thinking for exterior light etc .
1.00 would be fine, if it wasn’t for 2 feet of insulation sitting on top of it, and it’s the main feed cable from the CU.
Why I use two sizes? I bought 1.00 in error, used it for some downlights etc, but next visit to wholesalers, I got 1.5.
Using both drums up now.
So your mistake then? can't see how you can try and convert people due to a mistake on your part.
For a small property (e.g. 3-bed semi-sized) then I normally use only 1mm2.
For a larger property (e.g. 3 storey mansion with longer cable runs) I typically use 1.5mm2 for the feed, which is nowadays going from CU to switch to switch. Then 1mm2 from the switches to lighting points, which will often be a string of downlights.
Not a problem to have reels of both, in fact I make sure I've got supplies of both.
I think the norm used to be 1mm for downstairs lights and 1.5mm for upstairs to account for possible insulation which sometimes people put masses of it...
Personally I just use 1.5mm, for the simple reason that I only have to carry 2 reals, 1.5mm T+E and 1.5mm 3core and Earth rather than 4 reals.. I agree its a bit of a waste of copper but also prefer working with 1.5mm as when it goes into a screw terminal its less likely to break off... But thats just personal preference, I might change if copper prices keep going the way they are though..
I started off using 1mm , then moved over to 1.5mm as the price wasn’t much different back then
now I almost exclusively use 1mm for domestic lighting , I do have some 1.5 part rolls to use up if I feel it’s necessary
LukeD
Supporter
1mm or 1.5mm for all internal light runs ?
LukeD,
LastManOnline,
