I dont see the point of some half-ased rewire that wont allow wall chases , ring mains , and reuses old socket positions in skirting ???
Its either done to current standards or walk , to be quite blunt.
can't chase the walls cos it's a listed building, minitrunking very difficult cos doors everywhere and conduit too tight for 2 T & E's .maybe could pull 6 2.5's but doubtful
The minimum height of sockets/switches is a recommendation in Part M of the building Regulations covering use of buildings, it is not part of the wiring regulations. Part M states that the minimum height is not applicable to extensions or change of use of dwellings.
If you can raise the sockets within the space of the skirting board and fill/ board beneath them this may be a good thing but you do not need to go to 450mm.
Thanks for clarifying that.I've just found it in the OSG that it doesn't apply to re-wires.that should be in BOLD TYPE-it matters!
Do you have a copy of the Regs? If so what do they say? Are you Part P compliant - I guess you are as you advertise as an NICEIC Domestic Installer and an Approved contractor - so do the Building Regs apply in this situation?
That's not me, bud.that website is someone else.yes i do have regs but to save me trawling through them, I thought, I know, I'll ask those pleasant chaps on electriansforum to save some time
I'd be tempted to try drilling a big hole (20mm masonary bit) down behind the skirting for cable run and mount sockets just above the skirting.....works well for upstairs circuits but only possible downstairs if there's wooden and not concrete flooring.
So how do they manage on Grand Designs? Lots of listed buildings on there with chased wiring
A special clause in the 17th appendix - relating to the Kevin McCloud or Connor McCloud of the McCloud clan and the quickening, and they're family being exempt from normal reasoning.
Or presentation skills
Allow me to rephrase it then. There are many hundreds, probably thousands, of listed buildings up and down the country, I've had the privilege of working in a few. I have never heard of a rule which prohibits chasing walls, could you point me in the direction of it please
There isnt any.
i've done a rewire of a grade 2 listed cottege - we beat the crap out of it during first fix.
depends on the building. we've worked on a grade II 350 year old cottage with plaster and larve walls in which all wiring had to be surface and no holes drilled through the main structure.
it's on a housing Estate in a block of flats. I was informed by their head office that the buildings were listed and chasing was not allowed
50 year old radial sockets at floor level
electrician4u,
Dan,
