Discuss 50 year old radial sockets at floor level in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
E
electrician4u
Doing a re-wire for a customer who doesn't want surface mini trunking, can't channel walls and wants me to use 50 year old conduit to re-wire.It was originally wired as a radial circuit and don't think I'd get 2x2.5 mm T & E's down the conduit.Assuming the kitchen can be done seperately, could I re-wire the rest of the sockets as a radial and put it on a 20 breaker? Another problem is existing sockets cut into skirting at floor level.Is it compusory to raise these to above 450mm or can I just mark it as a deviation?
As long as you can get access to the draw boxes etc just wiring it in singles should be straight forward enough. A lot less cleaning up as well.
I'd be concerned about stressing the flexes entering the plug tops. You can get some skirting trunking that doesn't look too hideous.
good point i missed that, i read it as they were ontop of the skirting boards. i changed a board at a house recently that had sockets on the skirting, couldn't get my plugtop lead in some and had to use a socket and see tester as they were so low. i told the customer they should be raised and wrote it on the cert in the comments section
Some idiot is advocating cable entry on the top surface of plug tops there. No wonder I steer well clear of that asylum.
For some reason I always remember someone telling me that you cudnt have sockets in/on skirting board :/ can't remember why. Only thing I ever thought was that it is a fire hazard.
Sent from my BlackBerry 9360 using Tapatalk
There's loads of buildings out there with them in the skirts Jenions, it was the way it was done years ago. Stress on the flexes is why it's a no no now.
Ooooo like I said It was one of them things that I cudnt quite remember the reason just that someone had said it to me. At least I know now ey
Pulling 4.0mm singles through the conduit will be almost certainly be just as easy or hard as pulling 2.5mm and give more leeway
You will probably find the conduit is also via the kitchen,this will open up more options for pulling in extra cores or including the kitchen sockets,there will also more likely be a pipe for the cooker circuit that could be utilised for a seperate kitchen supply,radial or ring
The possibilities are many and these need to be decided upon beforehand, in the light of what pipes are existing and what can be wired to where
If I survey a property and there are conduits,I tend to think this is a lucky day indeed
My Aunt has some sockets mounted in the skirting and on two of them the sockets are mounted upside down! (not by me)
For some reason that reminds me of my old primary school; in one of the classrooms there were only about 3 single sockets, the most 'accessible' one being in a corner, up by the ceiling. If the teacher wanted to play us a tape she'd stand on a chair to reach the socket, plug in the tape player and balance it on the top corner of the wendy house, held up by the flex.
'Health & Safety' would have had a field day if they'd gone in there and if they'd existed at the time.
I dont see the point of some half-ased rewire that wont allow wall chases , ring mains , and reuses old socket positions in skirting ???
Its either done to current standards or walk , to be quite blunt.
Reply to 50 year old radial sockets at floor level in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I`m looking for an advice. I have an electric shower that I`m not using due to boiler changed to combi and added shower over bath feed by a...
  • Locked
5K
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
Hello all, Just some advice... I am fitting insulating boards on an external wall in a bedroom (50mm thick with plasterboard) as the end terrace...
4K
