Firedragon
I'm not a qualified electrician, just diy. I need to add 4 double sockets above the workbench in my study. The total load isn't going to exceed 13amps. I considered just using a 5m 8 gang extension lead from the existing socket on the other side of the room and pinning the cable to the skirting board, but really I'd like the sockets more spaced out along the work bench. So I have 2 options. I could wire 4 double sockets together, put a 13amp plug on the end and just plug it in to the existing socket on the other side of the room. But I know this isn't considered best practice. Or I could try and put a FCU next to the existing socket as a spur and wire the extension sockets into this. The existing socket is flush to the wall and I don't want to be chasing the wall to run cabling. I just want to pin the cable to the skirting board. Neither do I want to take up the carpet and the floor to try and find the ring and extend it. I'm looking for advice as to whether the above 2 options are ok and conform to Part P (I'm in the UK). Obviously the easiest option would be to use a 13amp plug, but is this OK to do? And do I have to use Twin and Earth or can I use 1.5mm 3 core cable? Even from an FCU?
- TL;DR
- Adding sockets: FCU or can I use a 13amp plug into another socket? Do I have to use Twin and Earth or will 1.5mm 3 core cable suffice?
