washin up liquid eh?.....jesus wept...don`t you dare!!
to the O/P.....go and get some 77........
Aye, too right.
personally i would have run one 20mm and 5 x 6mm should go through with swept bends you can share the earth and t box to first isolator then angle box up to second isolator i dont see a problem i am positive you can get all 5 x 6 mm in one 20mm conduit unless you are useing double insulated but there is no reason to if its in conduit
well ive seen em with that many cables in em eng....its a wonder how they ever managed to get em all in there at all...I take it then, that you have never heard of maximum conduit fill?? Your suggestion would contravene just about every rule in the book!! lol!!
heres a prime example of something i came across a bit back at a factory i was doin some work on....lol...
its old trunkin eng.....with all the lids of ov it (side mounted)........i found it to be overpopulated......together with neutrals entering metal enclosures on their own.....and other nastys like that.....That doesn't even look like trunking to me, more like structual steelwork??
Needless to say, that amount of fill through a male bush, is just not acceptable!! CODE 1++!! lol!!
as you seem to be quite the expert can you tell me the maximum % fill in a conduit and then also tell me what the % fill will be with 5 x 6mm singles in it ? my guess is that it does not break any rules but not having tried it i dont know if it breaks the rules or not so i better just ask the expert !!
Yellow 77, smear it on mu knob daily, who needs KYwashin up liquid eh?.....jesus wept...don`t you dare!!
