These work well with an impact driver but with a standard drill they tend to stop just before they exit the joist as the screw tip protrudes and is unable to pull the blade into the wood.![]()
use those, will drill faster ,like a knife through butter .
when drilling through timber you must pull back to clear the drill bit and it go through quicker and will not stop until you are at the other side of the wood .These work well with an impact driver but with a standard drill they tend to stop just before they exit the joist as the screw tip protrudes and is unable to pull the blade into the wood.
I remember going to a new build (being built by a gang of Bulgarian builders). They were using the wooden FinnJoist(?) I-beams. These are made with a number of push out holes in the beams.I beams everywhere![]()
