Hello I hope you are all well, can this fitting be used as an under cabinet light in a kitchen? I assume as its an LED fitting heat won't be an issue? Thanks Andi
www.toolstation.com
V-TAC LED Weatherproof Fitting IP65 6500K
Light up your outdoor space with this 6500K V-TAC LED lamp. The batten is a popular choice in areas exposed to moisture, humidity and dirt, such as garages, warehouses or sheds. This waterproof fitting is IP65-rated, so it's resistant to dust and sprays of water. It has a 120° angle beam, making...
