- Reaction score
- 5,662
Evening chaps..
I have just fitted some downlights in a bathroom and needed to give them RCD protection as there was none. I fitted the following:
![rcd unit.jpg rcd unit.jpg](https://electricians.s3.eu-west-1.amazonaws.com/data/attachments/15/15825-6dd998b6f858b115e37ed1873ab11050.jpg)
The test button works fine and the unit trips when a fault occurs (touching neutral to earth) but I cannot get the MFT to test it for trip times which I need for the MWC. Its a fairy decent MFT and I've never had any trouble with it testing RCD's before but I have never tested this sort of RCD before, it has always been in the CU. I make contact with the live/neutral/earth of something which the RCD is feeding, I get the little 'tick' on the MFT and then it just wont test.
Am I missing something simple here? Is this unit tested in the same way as you would an RCD in a CU?
