Search the forum,
Discuss changing cu with no cpc in lighting circuits in the Australia area at ElectriciansForums.net
flukey
hi all,
got a cu to change on mnoday where both lighting circuits have no cpc.
done a few before and nearly always because home owner wants to keep price to a minimum :rolleyes:
i obviously mark it on eic and correctly label the cu so it all complies.
just wondered what others thought regarding this scenario as im not turning any work away at the moment :p
hi julian
i have that best practice guide already mate, just wanted to see other peoples opinions on doing it as we would all obviosly rather do a rewire ;)
Hi,
I normally fit class 2 fittings and accessories, then continue with consumer board change. Obviously extra charge for this.
Also put warning label at consumer unit.
If customer says no to class 2 fittings, then I walk away.
Sav
hi sav
yeh thats a bit of an obvious one mate, all class 2 fitted anyway :p
reason for me asking is she had 4 estimates and i was the only one prepared to do it, other 3 said rewire or wouldnt quote :confused:
suits me ;)
I would suggest a rewire initially, If their answer was there's no money, class two and I wallpaper the inside of their understairs cupboard with stickers. Surprised that the other 3 companies weren't interested or didn't know their regs I would bite your arm off for any work at the moment:)
I suggest maybe putting a small declaration together and getting them to sign it.
There is no resaon why you cant change the CU without rewiring. If anything it will be safer than if you left it.
However, dont forget that you may still be responsible if something should happen in the future.
They might be my cousins company that he works for is, and there based in Dagenham east and he's running around like a mad thing. Nice snow pun :)
Jason the NIC do thoughs danger certs you can get the client to sign if it's really that bad then you register them like any other minor works etc you've probably seen them anyway.
They do know their Regulations in fairness. The Regulations does not permit such a get out clause, it's simply guidance which, it should be said, does NOT come from the IEE.
Incidentally, how do you sign an Electrical Installation Certificate with something which clearly does not comply with the Regulations, nor does it provide an equivalent degree of safety?
installs not that bad. just missing cpc`s. im quite happy marking it on the cert and stickering their nice new cu up, cant believe others arent :confused:;)
Silly question possibly, but would the patress screws become live if a loose feed came out of a terminal and touched the metal back box?
Yes they would mate, thats why you should idealy use plastic boxes, or plastic screws.
If it was my house, I would replace the screws with plastic ones.
the elecsa website had a good download manul on exactly this subject. Look at right hand sise of home page click downloads. There is lots of info there.
i will be changing the switch plates for the ones that have the white plastic push in covers that hide the screw heads so this isnt an issue ;)
I know this may sound a bit thick:)
But I thought generally the regs prevent us leaving an installation less safe than it was previously.:confused:
I know what the ECA guidance is on earthing to lighting circuits - but wouldn't installing a new CU with RCD protection actually make the installation much safer than before?
Although I know that the entire installation should be tested before installing the CU, I thought that the EIC would cover the CU work only??
This isn't a major problem for me as I will just follow the ECA guidance.
I just wondered whether anyone could explain???
Cheers
Reply to changing cu with no cpc in lighting circuits in the Australia area at ElectriciansForums.net
I've tried to research and form a plan without asking on here, but I'm just going around in circles. Just completed an EICR. The wiring ranges...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
When I checked out this job I had a false sense of security from a recent competent looking EICR and two new CU's that looked to be fitted to a...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
