C
Chrisl
Hi guys,
I am completly stuck, I am replacing my Kitchen Light Switches with new Chrome switches, I thought it would be just a quick straight forward swap, how wrong could i be!!
There are 2 separate lights in the kitchen on a 2 gang switch, indepently controlled by the same switch (2 buttons). After removing the current swicth, its an old tenaby switch and there are 3 conectors on the top and 3 on the bottom and 7 wires + earth.
The new switch as 2 holes/connectors on the bottom (both saying common) and 4 holes on the top (L1/L2/L1/L2) - Obviously very differnt to original switch
I presume the 2 lights have 2 cables each, one red and one black, I am then left with 3 remaining wires, one blue, one yellow and one black, i also presume blue is neutral, not sure which is the live feed?
Doesnt anyone have any idea how the heck I wire this lot up as I dont have a clue and dont fancy blowing myself up!!
Any help with be much appreciated!!
he meant that i'd travel all the way to suffolk and back to do a 1 hour job for £40. he was joking.
I really didnt think I would cause all this, I am sorry I just wanted some help for fitting a light switch. i think some people have not read fully what I said, I havent removed anything, all wires are still hooked up to the original switch, I just unscrewed the switch and had a look at the wiring configuration, nothing else! All I am trying to do is put in a 2 way switch for 2 independent lights, the new swticth is slightly different than the last!
Sorry lost on me I thought he was saying that was expensive
- - - Updated - - -
if you post a picture you are more likely to get some help
that makes it a bit clearer, but without a photo, we'd still be guessing. what i can say is that all the wires actually terminated in the switch will be either lives or switched lives. none will be neutrals. each switch will have terminals C, L1,L2. irrespective of how they are laid out physically, you need to fit each in the same as it is in the ols switch, one terminal at a time. however, some installations, installed in 60's and 70's were installed without cpc's ( earths ) on the lighting. if this is the case, you can't fit metal faceplates. if you do have cpc's, then the faceplate must be earthed rather than the cpc's being terminated in the back boxes. i do strongly suggest getting an electrician in to verify that it's safe to fit these new switches and that the wiring is fit for continued use.
Also I do not think any qualified spark would let a first day apprentice carry out this task, so I think it will be difficult to get a explanation here when you have no one to supervise you like they would.
not sure. but wqhen i opened a photobucket pic last week i only got a bit of the picture filling the whole screen and no way of dumping it.
Complete Novice trying to install new 2 Gang Light Switch - please help!!!
Chrisl,
Octopus,
