Have a job to change a consumer unit of old rewirable wylex type.
The existing is under the kitchen sink wiith the tails going directly through the outside wall into the meter cabinet outside.
With solid floor and built in cupboards all round and granite work tops is it acceptable to replace it in same location or does it have to be moved.
Note - Also due to extent of pipework etc dual rcd board will not fit and can only get an 8 way rcd incomere board in the space. there is an isollation switch in the meter cabinet but no movement on the tails which appear to go up the cavity a little behind the meter cabinet.
Move to cupboard next to sink
First thought was to do just that. Washer and then dryer on one side just before doorway so no chance that way. No way above as sink below window then corner cupboard on otherside so not accessable on same wall and if moved around corner would be directly next to oven with oven and hob isolation switches right there.
Joint cables under plinth and put in nearest cupboard
Thanks again for that. Only way to do that is to joint all circuits - and main meter tails - then run under sink and corner units then under oven to opposite side of kitchen.
Ofcourse i don't want to replace under sink if this is a no no. But if no regulation against it i think it is my best option
joint the tails with a henley in the meter cupboard outside....so their accessable....then its new tails to the new board position....how long`s the proposed run for the new tails....as you would be advised to find out the DNO requirements for this if over 3 meters....
as far as jointing the finals are concerned...again make any joints accessable wont you for future maintainance...
i dont see the point in moving a cu from 1 kitchen cupboard to another kitchen cupboard ?
customer gains nothing other than increased labour bill.
you are under no obligation to move it whatsoever , as the installation remains no less unsafe than when you found it.
and dont bother with all the usual stupid "what if a pipe leaks ?" panicky posts , its boring and predictable.
Nothing really wrong with it regulation wise.
As its an old install you can't really do much, and seeing as though you're not doing an EICR then i'd just leave it. Code 3 on an EICR max.
If it was a new install it'd be a different matter, can't exactly remember the height off top of my head but approved document M states a minimum height regulation which applys to CU/DB's aswell.
as biff and monkey have advised. fit in existing location. the chances of water damage are, IMO, slight, less than if the board was mounted below a shower on the floor above. and go with RCBOs.
Thanks again everybody for the sound advise.
Actually did get a small board with 100a incommer and RCBO's to fit today.
However, got there this morning and plumber had turned up to fit new Hot steamimg water tap, all new waste layout for sink and modify plumbing for washer feeds all under sink.
After pulling my hair out for a while and biting my tongue at same time, there was no way new consumer unit was going to be changed with all that going on.
Have taken the plunge and put new consumer unit in corner cupboard. Already a henley block in meter cabinet (along with 4 way consumer unit) by previous solar panel company.
Hope I get the new tails through the same hole as old ones, but does travel in cavity a little.
Now intend to joint existing circuits (crimps) in adaptable box as no way will they reach new board. Any do's or don'ts on that would be appreciated.
If other, please explain
Business Name
consumer unit change under kitchen sink
sidekick,
brucelee,
