- Reaction score
- 4,385
Wago junction box with these is the easiest and cheaper route: Lighting connector (294-4013) | WAGO GB - https://www.wago.com/gb/field-wiring-terminal-blocks/lighting-connector/p/294-4013
Discuss Converting pendant to downlights... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Like them a lotWago junction box with these is the easiest and cheaper route: Lighting connector (294-4013) | WAGO GB - https://www.wago.com/gb/field-wiring-terminal-blocks/lighting-connector/p/294-4013
My thought as well. Usually when you have several new spots being fitted it's likely possible that not just the switch wire but also the neutrals can be rerouted to one of the new locations and the existing pendant hole can simply be plastered up. No need for a MF jb.Reroute the light cable to the first downlight, then loop from there. No need for a WAGO box unless it’s got a pesky looped live at it.
Reply to Converting pendant to downlights... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
