Discuss Dimmer simple plugged in to socket cable with dimmer switch box in the middle in the Lighting Forum area at ElectriciansForums.net
JimmyJamo
I want to set up a simple plugged in to socket cable with dimmer switch box in the middle and a straight batten with bulb in for some bulb photography i need to do. I have a plug, two core wire, dimmer switch with box to encase it and a straight batten. Want to be able to dim bulb low. Can someone direct me please.
i think thisis a simple DIY job, and as such warrants a bit of advice. basically, wire plug as normal, 5A fuse. other end of flex from plug, L (brown) into C of dimmer, N (blue) into a connector. then from L1 in dimmer to feed L to lamp. N from connector to feed N to light, earths to be continuous from plug to light, where may be dead end terminated in a connector if the lamp housing does not have an earth terminal. once wired up , plug i, bearing in mind safe working at all times, no exposed live pars etc., etc.
Hi
Is the the correct configuration.
can'tsee whatgoes where from that pic, but the dimmer wiring looks OK
Secure those flexes with p clips or something also, to save any movement where they are connected.
Reply to Dimmer simple plugged in to socket cable with dimmer switch box in the middle in the Lighting Forum area at ElectriciansForums.net
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
Hi, I currently have 4 JCC LED down lights in my bathroom with a 2 gang dimmer on the outside. The first dimmer switch controls the LEDs and...
