Darkwood
Got asked to reconnect an outbuilding that the previous owners has disconnected from the house. No problem, new swa to the outbuilding and garage C/U fitted but had to laugh when I saw the existing set up. Apparently it was disconnected to get a satisfactory EICR for the house sale rather than fix the many faults.
Yeah water cooler, pulled it forward when pat testing then I noticed the lid was hanging off.
Two more
http://i.Upload the image directly to the thread.com/fELBSRk.jpg
Fuseboard had signs of burning inside and the main cable was burnt near the end and at some point I guess the original main switch burnt out and somebody changed the switch and stuck the cable back in. Luckily the property was getting a full rewire so it was all ripped out.
http://i.Upload the image directly to the thread.com/T33fGy7.jpg
Not sure how dangerous but rather unusual http://i.Upload the image directly to the thread.com/IwTt24F.jpg
Working on my mastery of the bleeding obvious - I go for 132.11 Prevention of mutual detrimental influence, so water and leccie should not be in same confinement. And since water pipe might leak, IP rating not sufficient. Thoughts?
and tell the wet-pants to go and buy his own bloody trunking.
Love the upside down socket! In the first photo it's possible the 2 sockets were fed from an FCU. I'm guessing this wasn't the case though. Daz
Or perhaps were part of a radial rather than a ring? Still rough as though. I've installed a couple upside down sockets before as the need dictated.
Got a call out to a house where the RCD tripped instantly when the MCB was turned on for the kitchen ring. Investigated the fault, located it was something load side of the boiler fused supr. Took the cover off the boiler to check the wiring and find this:
Blocked condenser leaked milky water alllllll over the electrical connections.
I think that's a bad habit you have. ;)
Found this behind an old consumer unit NOT ACCESSIBLE OR VISIBLE:
A freaking henley block! Luckily there was enough slack on the existing meter tails to connect to the new consumer unit without having to replace them.
Awesome. Never seen a MF Henley block before, maybe you should invent one, there's clearly demand for them!
I'm more surprised that volex board didn't catch fire
8K
Darkwood,
mainline,
