S
stubo300
we have a roof which is facing east and west, is it best to fit 10 panels on each side, if so what type of inverter would i need for this
I guess you meant maximise?
Can you not fit everything on the west facing roof? West is better than east because it gets the best of the afternoon sun which is invariably better than the morning sun. If you can fit everything on the west and use one inverter then it's a better system.
@Heather someone (a salesman? ) is spinning you a line (or 3)
The only limit to what you can install is your budget (and space whether that's roof or ground mounted) and whether you want the challenge of planning permission for a non-roof mounted install.
If you install significantly more than you'll reasonably consume then the income may be subject to tax (see the finance act 2008) if you have a large roof and consume lots of eclectricity then you could install 50 panels yourself.
The 'get rich' issue is to do with the very large ground array systems (1-5 MW) = thousands of panels that the governemnt hadn't planned for and is mainly financed by city investors, and the farmers getting a rent and revenue share.
(My Emphasis)7.37 Households can also play a part in generating low-carbon energy by installing smallscale renewable electricity generation on site. Feed-in tariffs, worth on average £900 in 2010 for households, will provide a financial incentive to install renewable technologies, allowing homes to generate around half of their own electricity. The Pre-Budget Report confirms that households who use renewable technology to generate electricity mainly for their own use will not be subject to income tax on feed-in tariffs. This will save households paying the basic rate of tax £180 in 2010. If necessary, legislation to ensure this treatment will be introduced with effect from 1 April 2010.
As such theoretically even someone with a 3.68kW system may be liable to tax if they are a very small user of electricity.20 Income tax exemption for domestic microgeneration
(1) In ITTOIA 2005, after section 782 insert—
“782A Domestic microgeneration
(1) No liability to income tax arises in respect of income arising to an individual from the sale of electricity generated by a microgeneration system if—
(a) the system is installed at or near domestic premises occupied by the individual, and
(b) the individual intends that the amount of electricity generated by it will not significantly exceed the amount of electricity consumed in those premises.
(2) In subsection (1)—
“domestic premises” means premises used wholly or mainly as a separate private dwelling, and
“microgeneration system” has the same meaning as in section 4 of
the Climate Change and Sustainable Energy Act 2006.”
