T
tom79bmth
Hiya
Just looking at a job there is no common area supply and the flat I am going to rewire, cu- board is in the common area they got the supply for the fire alarm from his board, I want to move the board into the flat, so the fire alarm supply will be in the flat so if he is away and it trips may cause problems.
Any advice
fit a 1 way CU for the fire alarm in the common area where the existing flat CU is now. just a 2 pole isolator and a 6A MCB.
Yeah good advice Tel, and to add you can buy a red board which matches your description from most wholesalers specifically designed for fire alarms, good shout Bud.
That's a bit rare isn't it, One resident paying for the running of the blocks fire alarm system?? ...lol!!
Hi,
Where I did the job last week ( my brothers flat ) they all chip in at the end of the year ( 4 Flats ), but because it's only a minimal charge and they all get on well he has never collected any payment.
Regards.
normally the landlords have a seperate meter and the Fire alarm connects to that, if it isn't the case then the landlord needs to ensure it is IMO.
should be connected to the landlors supply as does the staircase/passage lighting
and should be wired in fp
So who pays for the communal lighting then?? Now that isn't going to be a particularly low charge every quarter or whatever!! lol!!
They all own them private, so no landlord by the looks of it each flat does one light each so kind of equal
Sounds more like a lash up to me!! So if the guy living on the top floor turns the lights on each landing/stairs and doesn't switch them off as he goes who's paying?? Or is each switch a timed switch??
By the way, all flats are leasehold, so there is always a landlord as such. In this case the owner of the buildings freehold Deeds!!
all the flat conversions ive worked on in bmth had a l/lords meter in the mains cupboard and the red fire switch
the door of the cupboard was locked so the noone could switch off the f/a panel
i cant see any other way of doing it
fire alarm block of flats power supply
Security Alarms, Door Entry and CCTV (Public)
tom79bmth,
tazz,
