Discuss Flex connector - no earth on lights in the Electrical Forum area at ElectriciansForums.net
I have a cable twin + earth coming from wall switch with 3 amp fuse - I want to connect it to some LED lights with a flex connector. LEDs have no earth, so what do I do with the earth wire coming from switch to flex connector?
littlespark
The flex connector will have an earth terminal, put the earths in there. They must be connected through.
Sounds like the fitting itself is class II, double insulated (square within a square symbol) and does not require an earth itself.
Reply to Flex connector - no earth on lights in the Electrical Forum area at ElectriciansForums.net
Hi.. Newby here.. I have a couple lights holders/bulbs on the end of a flex plugged into the mains 13Amp plug. I want to put an inline switch on...
I have some PECSO HO7RN-F 3G1.5 Flex cable that i want to use to wire up some outside LED security lights that are 240v. The cable will be clipped...
I am replacing my under counter oven with a new 3kw one, oven is on its own circuit and isolation oven switch, the cable is either 4 or 6mm coming...
Afternoon everyone, I have a quick question about the Tesla Gen 3 Wall Charger? Does it require Type A 30MA RCD protection or not. Only because...
Hi, the new lights I have are metal and the earth connection doesn't connect to anything. I noticed the light that was there before someone had...
New Posts (Please Reply)
