M
Mynamesmatt
So Ive just bought a house and Im going to replace the fuse board as its ancient!
Just need to be sure on what i need to buy and how i need to go about splitting circuits properly.
It looks like its a 6 way and a or 4 way (does that look right?) - pic below
So lets say we have 10 circuits.. I will also be adding 2 - maybe more. 1 for a shower and 1 for a saniflo toilet system
Would it be right to get one big CU to replace these two - say one big 15 way board (want to leave some spare for future) a crabtree starbreaker 15 for instance
And the next question is what is the proper way to split the circuits and what will need to be RCD protected and which will not..
At first glance i think the circuits will be as follows; Upper ring - Lower ring - Kitchen - upper lights - lower lights - shower - saniflow - boiler - alarm system
Dont hate me for my ignorance, i am an electrician but i havent touched domestic in... ever! :33::ninja:
Also, all the cables are relatively new, all twin and earth - looks like it was rewired 5-10yrs ago but the board was lazily left out!
If theres any info ive missed just say
any help would be MUCH appreciated as i have to start digging into my wallet for materials pretty soon!
thanks!
Well I could be wrong here but there is 2 meters and 2 supplies I take it there is some off peak equipment and if this is the case you still need 2 CUs
or 1 CU and a dual tariff meter. the crabby starbreaker sounds good, but BG do a biggish CU at a better price.
You sure you know about electrics?
Take off the removeable covers and have a look! It looks to me like a 'peak' fuseboard and an 'offpeak' fuseboard - clue is that there are 2 meters!
Changing a CU is notifiable work so should only be done by a Part P electrician.
I'm not being hard, just realistic in what your capabilities are, shown by your questions.
also top left of picture shows a timer,covered by sticker
So i could get the suppliers in to change the metering to dual.. then go ahead with one tidier board..
either that or get a double stacked CU and have a peak bus and a off peak bus?
Im a fully qualified electrician but not part P/2391. i work mainly industrial... big armoured's and panels etc.
I was planning on doing the work (&upgrading the bonding etc to part p requirements) then getting a registered body to come in and 'sign it off'
Can imagine thats going to make some peoples fists clench reading that!!.. but is that a possibility? I am on one hell of a budget you see
oh - and i couldnt get in and take the covers off etc cos the house isnt ours just yet. was just a quick picture whilst the solicitors let us in
That wll be building control @ £350 .00 then!
Ok Matt You Oughta Know, and by the looks of it you don't no part p governing body will come in and sign off this for you without you being a member (in which case you would sign it off yourself and use them to notify it).
I know it's Dumb as a qualified spark that a 5 week wonder can do this but you can't But That's Just The Way It Is but if you know someone that's registered and will do this for you then fair play. Maybe your idea about the 2 busses ain't a bad way to do it.
thanks for the info trev!
If i wasnt an electrician id obviously get someone into do the job but i could never justify getting someone in to do it when im quite capable, just because i cant sign it off..
Ill look around for someone that offers a simply certification only job and see what they say i guess.
what a pain in the --- eh!
Matt.do like countless thousands of non electricians are doing and install the job yourself and forget the part pants fiasco
It galls me to hear that qualified sparks are having to pay some "council no nothing department" in order to do what they were trained to do
If ever you decide to sell and the buyer wants a part p notification certificate and its non existent, all that happens is a condition report is accepted by nearly every solicitor, also you dont need the part p fiasco for doing those reports
Its too crazy a failed system for me to advise a qualified electrician otherwise,If he can carry out industrial installation,domestic installation is childs play in comparison
Fuse board change help!
Mynamesmatt,
Strima,
