Hi
I recently quoted for the fitting of 2 outside lights and have carried out first fix all cables run to position etc.
On going back to fit the lights (customer supplied) they are low voltage which means I now have to uplift carpets, floorboards etc to fit trannys etc.
My question is - can I use my existing newly installed T&E for the output LV supply side to the lights or do I need to re-run LV cable to the lights?
