Discuss LED Bulbs too bright - any ideas?? in the Australia area at ElectriciansForums.net
A
andyww
Hi
I recently installed 4 decking lamps for a customer - the customer supplied the lamps which are IP 56 rated sealed units, with 2W super LED bulbs. The customer has called to say they are extremely bright and do I have any ideas for making them less so. (he attaches no blame to me as he supplied them) I cannot change bulbs as they are sealed units, they have a slightly concave glass lens which I wondered if there was anything that could be painted onto - maybe coloured varnish? Heat won't be a problem as they are 2W LED's.
Anyone have any ideas/experience of this??
Andy
Thanks Gerry - thought of that but the class is not flat so would be difficult/impossible to fix them - that's why I thought maybe a coloured varnish might do the same thing? I know you can get paint specifically for colouring glass
If you can get to the transformer supplying the bulb you could have a look to see if there any other taps on the transformer to either reduce the output voltage or move the input to a higher tapping. OR, solder a small wire wound resistor in series with the bulb supply. OR the amber glass paint from halfords or similar places for converting car headlamps to amber.
Just thought of another one. What about a dimmer on the supply.
Thanks Boatnik1
Lamps are 240v run from a switched FCU so dimmer etc no good! - Looks like a trip to halfords......
Thanks for the suggestions
Reply to LED Bulbs too bright - any ideas?? in the Australia area at ElectriciansForums.net
Hi guys! Hoping you can help me. I'm making a custom 12v motorcycle brake light. I'm at the stage where I need an LED board/unit that does both...
J
Hi guys! First post here but REALLY need some help! I want to use an extremely bright LED or very small bulb and a laser module in the same...
M
The History of the Incandescent Lamp. Around 240 million light bulbs were sold each year in the UK. [1] Incandescent lights work by using...
alarm man
A
