Discuss LED don’t work in the Lighting Forum area at ElectriciansForums.net
@john watts is a forum sponsor with InstyleLED. Perhaps he can offer some help?
Have your existing transformers got a min/max power rating stated on them?
The existing transformers are unlikely to work with new LED lamps.
Post up what new lamps you have. If it were me, I would replace the whole fitting with a new 240v down light.
Wouldn't be surprised if the wattage of the LED replacements are below the minimum requirement for stable operation. You will likely need new drivers.
Midwest, you bet me by seconds there.
LED lamps require a slightly different technology, and their 'transformers' are called drivers. They can be either constant current or constant voltage drivers, dependant on the requirements of the lamp. Buying just an LED lamp can be a bit difficult to assess the compatibility. I would return your led lamps, and buy a product that supplies both the lamp and the driver.
Edit; replacing with GU10 lamps and or new cans or down lights, would negate the need for separate drivers. You could even consider sealed units.
JCC v50. 240V and selectablr colour temp.
Agree with above.
Presently you have 2 hotspots. The lamp and the transformer. Neither like insulation above them, and you’ll find the plasterboard around the holes quite brittle.
Easiest method is the all-in-ones. Quicker to fit and most are the same hole size as the older downlights.
Basically, transformers give out AC current, and drivers are DC, specifically for LED circuits.
Reply to LED don’t work in the Lighting Forum area at ElectriciansForums.net
Hi all, I am trying to replace my halogen wall uplights (230W, 240V, R7S, 114mm) with LED but so far no luck. I've tried both of the below LEDs...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
Hi all, I bought a house and went around replacing the mr16 halogen downlighters with LED lights. The lights are controlled by a Quinetic smart...
Done a job yesterday, remove old 12v halogens and replace with mains, gu10 downlights. Fitted some LED gu10's no issues. Got a call today saying...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
