cliffed
Just wondering if anyone connecting led lights had any problems connecting them ,these inserts are tiny ,they are wired in 1.5mm,loop in system,not yet 2nd fixed,it just don't look easy,cheers.The supplier says there is no probs,but he would.
Guessing they're mains ones (check!)... so no (external) driver reqd. So just the usual mechanical probs of getting cables where needed. Fitting them on stair stringers can be a hassle. Without knowing where they're going can't really comment more.
use a wagobox or something similiar, put the loop in and out in there, get one small cable out into the light.
next time loop at the switch if you are planning on using modern lights.
terminating 3x1.5 into something else than a ceiling rose or fitting designed for it is a nightmare.
cliffed
Worcester
United Kingdom
Electrical Engineer (Qualified)
Led small insert light
cliffed,
amlu,
