Discuss Need Advice on Possible Causes of Whining sound and power-drops in the Auto Electrician Forum area at ElectriciansForums.net
SkyyStorm
Hi.
I want to start to say that I've had this problem for some time now. I've given my car to more than one auto-electrician in an attempt to have it fixed, but they have to date only cost me money with no result because I can't give them enough information on the problem.
My car :
2009 Hyundai Tiburon
102 000 kms on the clock
Serviced at 95000
Battery replaced at 98000 (while the symptoms were already present, was tried as a possible solution)
Here is a description of the symptoms I experience :
1) While driving, I will start to hear an audible high-pitched whine, seemingly coming from the passenger side of my car (near the ECU, but could be below the hood as well, hard to pinpoint). This sound increases in pitch based on my RPM. So increasing my engine's revs also increases the sound's pitch. Initially, this doesn't seem to cause any change in driving condition. However, in certain (very rare, mostly with AC on or with something plugged into cigarette lighter) cases, while driving, my car would suddenly lose all power. Engine, lights, radio, everything. This usually lasts less than a second, after-which the car restarts itself and continues on as if nothing happened. This happens only if I have AC on, or if I have something plugged into the cigarette lighter.
2) Second symptom happens when I stop. If the whining sound was audible while driving, and I stop and turn off the engine(but still have the key in ACC), very often all power will drop. All lights, dials, even the radio, everything off. After a few seconds, it will either come back on, and everything will work as normal, or it will go into a strange low-power state. If I open my door with the key in ignition, the door light is really dim, and the door-open-with-key-in-ignition pinging sound will not be audible. Trying to start the car will completely draw the power dead, causing the dimly-lit lights on my dash to completely disappear (similar to what happens if your battery is almost dead).
This 'low-power state' can be fixed by one way only. If I move the cables around near the positive terminal of my battery, it will eventually suddenly get power, and then everything resets back to normal. Then I can start the car, and the whining is gone, and everything works as normal. The radio and clock is reset though (as if the battery was disconnected).
The high-pitch sound symptom almost never occurs if I only use the radio.
It sometimes (once every week or two) happens if I use the Air-Conditioning.
It always happens if I plug something into my cigarette lighter.
I can change the loudness of the whine if I move the plug in the cigarette lighter (a charger plug). Pulling it out doesn't stop the whine though. Sometimes it will simply disappear eventually while driving, other times it will go on until I stop, after-which symptom number two appears.
I gave the car to an auto-electrician. He tested the ECU and a few relays and also told me that there's nothing wrong with the battery cables (that I move around to fix the low-power state?!), so didn't replace them. I also tried replacing and testing the battery and the alternator, both were fine.
My current thoughts are to replace the battery cables altogether, as that is the general consensus as to what the issue could be despite the auto-elec's opinion. But the problem seems ground-related, specific to the AC/Radio/Cigarette lighter. But I find it odd that I can fix it via the battery cable.
Any advice? Ideas? I just want some possible causes I can give through to the auto-elec, or try to fix myself, so that I don't waste more money before I have more information.
PS. I might have understood this forum incorrectly, I am not a electrician in training, or an existing one, so if this is only for auto-elec professionals or trainees, then I apologize, and will ask my questions elsewhere.
I would also say this is a connection problem. Possibly earth, or where the positive diverts to distributions.
I am not familiar with this model, but it is consistent with power failure . Check all earth and positive connections.
PS. Some cars have relays under the ecu , you may have a loose or faulty relay somewhere.
Hi.
My car :
Serviced at 95000
Sorry couldn't resist "leave your other half at home" got the same trouble when I take her in doors to the shops, stops when she gets out, very strange
I had a similar problem with my Vauxhall astra van, it turned out to be a faulty alternator, it was dropping the voltage to around 6v then going back to 14.2v test. changed that and never had a problem again.
poor connection of battery terminals. first get a spare, charged battery with jump leads. connect to car battery leads. then remove clamps from in-car battery, clean and refit. the spare battery connectionis to safeguard the car's electrics from reverting to japaneseand losing your nelsonmandella radio preset.
The auto-elec I used replaced the relay near the ECU, thinking it might have been the problem. Sadly not.
The alternator was checked by both the Auto-elec and a battery-centre, both said that it is outputting the correct voltage.
I will consider replacing it however if I keep struggling.
I really don't care if I lose presets lol. I think (and hope) the cheapest thing to try first would be to replace the battery cable, housing and maybe even the diverting cables with new ones, and see if that solves my problem.
The fact that the power completely drops when I turn off the car implies that the connection somewhere gets interrupted when the alternator stops supplying power, but that's just an uninformed assumption I'm making. :p
Thanks for the replies.
Connect a multi meter to the battery connections and watch the voltage carefully, I had the AA out 4 times to my van to sort the issue on my van 3 said nothing was wrong, the last one put a meter on, started the engine and had me turn the lights, heater and aircon on and watched the voltage, the engine revs picked up slightly as it should then after about 10 mins the voltage just dropped for a second then came back and it did it a few times.
Reply to Need Advice on Possible Causes of Whining sound and power-drops in the Auto Electrician Forum area at ElectriciansForums.net
Last weekend I experienced a weird electrical fault with my 2010 Peugeot Boxer Van. A little background - the van is a 2010 Boxer 330 2.2 Short...
Once again I am using the Engineering chat as I think my question is more theoretical rather than 'diy advice'. If I am misusing the forum...
I recently buyed a Opel Astra H GTC. It has a CD 70, with Bluetooth and AUX etc. So for music I used used AUX, cause the previous owner left me...
The symptoms its been having to start with was the fuel gage only working sometimes and when i play music from my phone when a loud song came on...
Hello, Not an electrician and I currently live in an apartment building. Over the past few years I have been having abnormal problems with my...
