Discuss No cpc on lighting and no neutral continuity on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
And unless you take a bit of a scientific approach with additional testing it'll always be the very last socket that you open up with the dodgy connection. :)
Decide which one you are going to start with, then change your mind and go for one at the other end. Then you will always find it at the first one. Simple. Not in the On-site Guide that one.
or a wood butcher hanging a cabinet above a socket. seen that t'other week. rawlplug and screw straight through a T/E 2.5mm.
New posts
Reply to No cpc on lighting and no neutral continuity on kitchen ring in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Old two core cable in a lighting circuit with no cpc at any point All points had metal fixtures and fittings class1 At two points the live loop...
Just to be clear… I am going to do the correct thing here and pay for the correct parts…. I just wanted to start the discussion. My particular...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
