Currently reading:
not enough room in the consumer unit ?
Discuss not enough room in the consumer unit ? in the Australia area at ElectriciansForums.net
J
Jak1708
hi all
if you had a consumer unit where all the CB's were used up and u need to run a new cable and cb to the board how would you all go about it ? instead of replacing the consumer unit for 1 more cb what would you do ?
ive seen people fuse spur off sockets then from the spur to a mini cu to feed that part of the instillation
but anyway let me know what u wud do ?
thanks again !
You could install a new additional consumer unit taken from a 40 amp or 50 amp circuit breaker off the original board and move a circuit out of there and then also add your new circuit that way you still only have your one main switch as required by regs
Reply to not enough room in the consumer unit ? in the Australia area at ElectriciansForums.net
