Hey all, I'm looking into a situation where a customer has been told they could no longer have oil delivered because of tank regs etc... so local DNO fitted them a new boiler (Electric) the old boiler was oil fired and 28kW new electric one is 14.4kW but running same amount of radiators. She uses the boiler only for the rads and immersion element in water cylinder for the dhw which as it's fed only off peak cheaper rate she says can't have a time clock to switch it on/off. Problem is her off peak supply is only on a 20 hrs in 24 cycle and DNO decides when it's off which is a.m. no problem but again 17:00-19:00 which is the problem as the whole house gets really cold apparently. She's been advised to have a booster switch on to override that 2 hour time when it's off she will need to use on peak electricity and it will cost many hundreds for them to fit.
I have only ever fitted booster switches into off peak hot water supplies etc.. is there such an item ? or would she need a new feed cable from main C/U to a big enough contractor which is triggered by a d.p. switch or something similar to manually turn on /off at 17:00-19:00 to run the boiler. ??
She also tells me that the smaller boiler as I thought runs constantly as it's much smaller rated. !! and to have a bigger one she needs to have a bigger supply to the property at £8,000 plus and a bigger boiler cost on top ! She also wants an alternative price for Farho's or similar to use for the 2 hr periods between.
Any advice would be very handy...
