G
Geordie Spark
Anyway, Ive took all the "advice" issued. Thanks.
Im off to quote on replacing 17 period lightswitches ;p
Good lad.
Take your time with it.
came across 'bakerlite' toggles recently, some appeared brand new and all were deemed ok. loose connections could also cause 'arc'. had modern switch that 'lit up' when operated. old might not mean unsafe.
To hear you ranting on?
Good lad.
Take your time with it.![]()
FINALLY you admit to being a troll.
rewire!!I should say the customer has asked for me to "upgrade where possible"![]()
Should I quote for 2 new RCD boards as the current 2 are non RCD ?
Cause I have !....I should say the customer has asked for me to "upgrade where possible"
- - - Updated - - -
lol defo not a troll, just don't appreciate the smart arse comments.
, if so that's an issue as potential access to live part without the use of a tool . I would code that as a 2 me thinks .
Are these the old switches where the covers are screwd on by Hand old Bakelite small round thingys ?
Funnily enough I'm doing a job in a old hospital witch is now a museum were I am using the old( looking ) bespoke switches on wooden backing fancy
Ha when I think an electrical accessory may be open'd by hand by absolutely anyone like a child or anyone . If a lamp holder is accessible to a child via bunk bed I've changed them before I think someone is at risk as with these switches accessible live part without tool . And with lamp holder I consider the use of a ladder to access a tool only an opinion witch I have . You give up ohhh I'm gutted il miss you
A code 2 Really?Are these the old switches where the covers are screwd on by Hand old Bakelite small round thingys ?
