Deleted member 102649
A little advice from a sage, please.
In the dormer bungalow we're renovating there is a three-way switched light for the upstairs landing, one switch in the hall, one (an intermediate) at the bottom of the stairs and one on the landing.
A lot of the wiring is well buried behind render/plaster, under floors, roof spaces, etc.
All back boxes are metal and earthed.
The bits of cable behind plaster appear to have plastic capping put on before it was rendered/plastered. Certainly the case where the plaster fell off elsewhere!!
The supply to the circuit appears to come from a junction box in the eaves, which I can get at quite easily.
I can see another junction box (looking under floorboards) which appears to be the link for the wiring running to and from the intermediate, as if the intermediate was a bit of an afterthought.
The common terminal on the hall and landing (outer) switches have a single conductor connected to them.
Neither of the 'outer' switches has two wires into any terminal
Neither of the two 'outer' switches have two wires into any of the terminals.
The intermediate has two runs of twin and earth only, ie, I assume it has no 'common' running through it tying in with my 'afterthought' idea.
I'm fairly sure I understand how it all works, I guess it is a fairly old setup (house built mid-70's) and it's a major digging job to change it.
Maybe worth saying it all works OK.
My questions are:
Is it likely to be unsafe, even though it looks tidy and quite well installed, properly earthed, etc?
What are the down sides of the setup?
I assume it's advisable (necessary, from a safety point of view) to swap the junction box that contains links for the intermediate from a screwed to a maintenance-free box?
My questions are:
