Hi, I tried to put a dimmer switch in. There was a little crackling and the light was flickering. I put the old light fighting back on and now the light I was working on is the only one that works in the whole house. I have checked the fuse box and all the other electric things are working. Would someone please able to advise on what I might have done?
Did you take photos of the old switch & wiring before removing it to fit the dimmer?
i.e. can you 100% confirm you have put it back as it was?
1 hour for a spark to fix. , £40 -£45. teach you to dabble where you are out of your depth.
Usually with tree plate lighting if it is wired wrong it normally goes bang or the other rooms will only work with the other room light switch on. In this case, I think that a cable is loose, broken or come out of the connection. I would be careful it's not copper-clad or aluminium cable.
does the rest of the house come on when you turn this one switch on?
You mention changing a switch, then a light fitting? Thats what is confusing us.
Did you change one, the other or both?
Sorry, I changed a light switch to a dimmer. I have since reconnected the original switch back and the light connected to that switch is the only one working in the house.
[automerge]1568476829[/automerge]
Nothing went bang, no fuses blew, the light I was working on is fine and all other power in the house is working fine.
leeds
One light working in the whole house
UK
Jordansenior,
telectrix,
