Discuss One light working in the whole house in the UK Electrical Forum area at ElectriciansForums.net
Hi, I tried to put a dimmer switch in. There was a little crackling and the light was flickering. I put the old light fighting back on and now the light I was working on is the only one that works in the whole house. I have checked the fuse box and all the other electric things are working. Would someone please able to advise on what I might have done?
1 hour for a spark to fix. , £40 -£45. teach you to dabble where you are out of your depth.
Usually with tree plate lighting if it is wired wrong it normally goes bang or the other rooms will only work with the other room light switch on. In this case, I think that a cable is loose, broken or come out of the connection. I would be careful it's not copper-clad or aluminium cable.
does the rest of the house come on when you turn this one switch on?
You mention changing a switch, then a light fitting? Thats what is confusing us.
Did you change one, the other or both?
Sorry, I changed a light switch to a dimmer. I have since reconnected the original switch back and the light connected to that switch is the only one working in the house.
[automerge]1568476829[/automerge]
Nothing went bang, no fuses blew, the light I was working on is fine and all other power in the house is working fine.
I bought a fixer-upper.
[automerge]1568477722[/automerge]
Stupid question but have you checked the bulbs?
Yeah, I checked them.
So the logical conclusion is that you have disconnected the rest of the lighting circuit.
How many cables are at the switch and at the light.
Reply to One light working in the whole house in the UK Electrical Forum area at ElectriciansForums.net
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
Hi all, I'm wondering if anyone might be able to help. We have a fused switch that controls 4 LED lights next to a power socket which have both...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
As you can see what I have is a right mess, IAM wanting to put a new switch on , but every thing I try either leaves one or two light not working...
