Discuss outside light installation & armoured in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
aaelectric
HI was wandering what cert you would issue for installing outside lights. Power is already in place. any may want to add some swa to it to extend? cheers
When you say outside lights, do you mean garden lighting or lights attached to the outside wall?
Lights attached to the wall are not notifiable unless they are on a new circuit or fed from a circuit in a kitchen etc.
Garden lighting is notifiable because it is a special installation.
With regards to which cert. to use, if it is a new circuit then use an EIC. If it is an addition to an existing circuit then a MWC will suffice.
its gardens lights led in decking, and maybe some armoured clipped to wall and the spiked spotligths around garden
So is any outside light notifiable like a sercurity light or a porch light??
If the light is fixed to the house wall and is not a new circuit or from a notifiable circuit and there are no exposed external junctions then you do not need to notify. If it is an outside socket fixed to a house then you do need to notify.
Reply to outside light installation & armoured in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Hi all, I'm wondering if it's permitted to replace an outside wall light myself if I use the existing wiring from the old light. In theory I just...
Hi all, I have a log cabin in my garden. An electrician ran an armoured cable from my consumer unit to the log cabin and this terminates on the...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
