Sbc
Should one insist to the customer to have a PIR before proceeding with a CU upgrade? if not what do you do if there are hidden nastys ie bad IR readings?
Discuss PIR before a Consumer Unit upgrade in the UK Electrical Forum area at ElectriciansForums.net
Main double pole switch off.How do you do a global IR?
I only really do by circuit through fear of damaging equipment but your way must save loads of time?
These questions may sound dumb but i really am new to this.
The regs say investigate IR <= 2mohm but for you guys personally, what low reading would stop you doin a fuse board upgrade? is there a point where you say #thats a rewire!
Can showers and ballests in fluorescents get damaged or infuence measurements during IR testing
Reply to PIR before a Consumer Unit upgrade in the UK Electrical Forum area at ElectriciansForums.net
