Discuss polarity argument at work in the UK Electrical Forum area at ElectriciansForums.net
Just to throw something else into the mix we use alot of prewired fittings on commercial install and they all come with brown switched and black perm on all the emergency fittings which the plugs are tamper sealed, this i guess matches the switched only fittings which as you know are brown switched. I know many manufacturers use this system so i stay with it to keep it the same throughout the job.
Only on domestic where i choose the colours do i use black as switched but this stems from the old colours.
Its a bit like a two way switch with what colour to common ? Does it matter as long as its marked.
Lenny don't tell me about my attitude please because nothing is out of line. And tbh Íve been sparkying for over 20 yrs now and I love my job and have a great passion for it and it really gets to me when people act thick and class black as permanent. Rant over !
You've got a cheek. A new member with 3 posts is picking a fight with a moderator - keep this up and you'll be banned!
Would suggest the electric chair myself....but I`m worried who might of wired it, can be dangerous things those chairs if you mix your browns with your blacks...
Reply to polarity argument at work in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm replacing a light fitting in the bathroom but the wiring is confusing me, black brown and grey? Is black neutral and brown live in this...
Hi, changed a bathroom extractor fan. Easy enough. I was dealing with a grey, black, brown and earth wire. When i tested the black wire, which i...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
