soulman
I'm installing a new circuit next week in a property that has solar panels. I will need to take a Ze, Can i just isolate at the main switch in the consumer or do i need to isolate the p.v?
Cheers
not too sure, but , IMO, isolate at the CU main switch, dis. the MEC and then get your Ze from the incomer and the MEC.
There is a routine to isolating the PV array safely.
The customer should have the papers detailing it.
Just turning off the PV main switch may well damage the inverter / convertor board, so do it as it says in the manual for that particular PV installation.
If there is no diagram showing the isolation procedure, do not turn it off, get the customer to get a copy. In fairness, I have come across 4 PV installations in the past year, and they all have the relevant paperwork available.
Switch off PV at A/C first (there should be a switch located at an accessible location) then turn off D/C, there should be an isolation switch for this too.
To turn back on D/C first then A/C.. This keeps the current going through the D/C switch to a minimum, it is also good practice to use fast switching on D/C to reduce arcing of contacts, but if any doubt turn off when it is dark, as no D/C will be being produced...
I hope this helps all sparkies..
soulman
Durham
Quick question
soulman,
soulman,
